Power motor driver composed of IN8510 and DAC7520
Source: InternetPublisher:ghaytweyhtoo Keywords: DAC motor driver switch CMOS Updated: 2021/10/21
Using two BTS412B as high-side switches and two BU271L power MOSFETs
(50v, 䉉1n) as low-side switches, an H-bridge bidirectional DC motor drive circuit can be formed,
as shown in Figure 11-1l. This circuit is designed for an electrical automatic door with a continuous current of 6A.
The four-leg switch is controlled directly by CMOS logic levels. The two BTS412B status outputs
are driven by a transistor with OR logic and an LED indicates the fault status. The middle point of the left bridge arm
is connected to a 12ktl resistor to the ground so that when all four switches of the H-bridge are turned off, the BTS412B will not
mistake it for an open load. Once a load open circuit occurs, the BTS412B on the right can detect
it and send a fault signal.
- How to choose the right level of integration to meet motor design requirements?
- Design of an autonomous plant watering system using ATtiny85
- Controlling LEDs with Node-RED in Raspberry Pi
- Introduction to the internal structure of the Delta winding motor
- Manual automatic air compressor control circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of wire control circuit
- Audio interface protection circuit
- Password type motorcycle anti-theft device
- TTL and CMOS interface circuit b
- Interface circuit between CMOS and switching amplifier a
- AC-SSR application circuit c
- Analog counter circuit diagram
- CMOS touch key circuit
- CMOS to TTL interface circuit
- Backup power circuit for CMOS RAMS
- Backup power supply for permanent CMOS RAM
- PMOS-CMOS interface circuit
- CMOS voltage inverter MAX660 circuit diagram
