The excitation power supply of the resolver is composed of a single OPA2541
Source: InternetPublisher:newlandmark Keywords: Resolver OPA power supply output voltage Updated: 2020/11/27
Indicates the wiring
circles of the two power amplifiers A and B of OPA2541. Pin 5 and pin 1 of the output terminal are connected to both ends of the original side of the resolver , using the bridge connection method. Amplifier
A is connected to a Wien bridge oscillator, and the nonlinear resistance characteristics of the incandescent lamp EL are used to
control the loop gain to maintain the output voltage unchanged. By R. , Rt, C-, C: The network forms
a positive feedback active filter, which determines the frequency of the output sine wave. Wind IR, determines amplifier
B gain. Four diode clamps protect the output voltage. R. C,,RsC. Used to
suppress noise signals. The excitation power supply composed of OPA 2541 has good temperature stability
. When the temperature changes by 60'C, the output voltage changes only 0.05%.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Car ice warning circuit sharing
- Use your smartphone to turn on/off the power in your home
- A small improvement to the temperature and water level indicator alarm
- Working principle of one Xipu STR soft starter controlling two motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Hydraulic control circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Audio interface protection circuit
- Bicycle anti-theft alarm
- Water and electricity saving infrared control circuit
- Microwave oven control circuit
- Table printing machine control circuit
- Three-phase stepper motor control circuit
- sound control circuit
- Range hood detection control circuit
- Sprinkler control circuit using AC motor
- Automatic sprinkler irrigation control circuit
- The excitation power supply of the resolver is composed of a single OPA2541
- OPA128 type operational amplifier
