Range hood detection control circuit
Source: InternetPublisher:aytwartoofyoroo Keywords: Range hood control circuit Updated: 2021/10/27
Shown is a range hood detection and control circuit . The main component in this circuit is the gas sensor MQ-211. When the gas
sensor detects oil fume gas. A DC voltage will be generated at point B. This voltage is added to the @ pin of Icl, causing the IC1 ③ and ⑦ pins to output control signals . The drive signal
of the @ pin causes the relay K to act and drives the motor to pump air. The signal of the ⑦ pin causes the oscillation When the alarm is activated, the buzzer will
sound and the LED will light up to indicate.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- In-depth analysis of energy losses in oscillation frequencies
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How to read resistor color codes? Resistor color codes illustrated
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Datasheet/Pinout/Technical Specifications of LMC555
- A practical automatic electronic welcome circuit
- Homemade air conditioner outdoor unit shutdown indicator
- Photocell amplification control circuit
- Electronic rhythm control circuit
- Chicken farm photoelectric control circuit
- Boiler control circuit
- Microwave oven control circuit
- AM radio automatic search and trigger circuit
- PLC transmission line automatic reclosing control circuit
- Relay control circuitb
- Detection and control circuit of electromagnetic stove
- Range hood automatic control circuit
