AN6657 schematic block diagram and basic application circuit
Source: InternetPublisher:fish001 Keywords: Application circuit BSP electric motor Updated: 2021/12/02
AN6657 is a 16-pin dual in-line plastic package, and AN 6657S is a 16-pin dual-in-line
flat plastic package.
1. Working principle of steady speed control: There is an H-bridge drive circuit inside the chip.
Pins 5 and 8 are the H-bridge drive outputs and are connected to the controlled motor . When pin 5 is positive, the motor rotates forward;
when pin 8 is positive, the motor rotates reversely. The positive power supply of H bridge is pin 9 and pin 11, which
is connected to vcc through external resistor r. The lower arm of the H bridge is connected to pin 6 and connected to the ground via an external NPN transistor.
- Design and selection of electric control valve system drive
- Controlling LEDs with Node-RED in Raspberry Pi
- How to set up a cheap beam break sensor control distance scene using a reflector
- A small improvement on the ordinary refrigerator motor starting circuit
- Working principle of one Xipu STR soft starter controlling two motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- One-way rotation circuit of motor controlled by contactor
- Audio interface protection circuit
- Night dog barking anti-theft reminder circuit
- Homemade anti-theft watchdog
- Set timing circuit when power is on
- electromagnetic field sensor
- Electronic anti-asthma circuit
- Varactor Diode Frequency Modulator
- Wien bridge oscillator circuit
- Capacitive feedback oscillator circuit
- Differential Amplifier Circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
- Sawtooth wave generator circuit (2)
