Application circuit of external tachometer generator
Source: InternetPublisher:常思一二 Keywords: Generator application circuit BSP electric motor Updated: 2021/07/16
According to the typical application circuit , when the power supply voltage changes to 6-16V, the motor load
torque changes to 0. 08-1. 2mN. m, the motor speed changes within 0.2%U.
The motor used here is a 3-slot, R.-16n, working speed n-2000r/min . The data of external components used in the
circuit are shown in Table 2-6. The table also shows the performance changes that may be caused by parameter
changes.
3 Other applications The chip can also be used for external applications of various tachometer generators,
such as electromagnetic single-phase AC tachometer generators, photoelectric encoders, Hall tachometer generators , etc.
Note that when the speed measurement signal is input from pin l, it is best to have a double diode clamp. In the example shown in Figure 2-43
, the control logic signal and speed setting level of pins 18 and 19 are given by the microprocessor
(given from the D/A of the microprocessor).
The 9 and 12 pin outputs can also be connected to an external high-power H-bridge integrated circuit (such as L298,
etc.) to expand the output current and drive a larger power motor .
- How to use a microcontroller to control a servo motor?
- Model rocket launch controller circuit
- How to Make a Simple Chicken Incubator
- Manual automatic air compressor control circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Temperature control circuit design and analysis
- Infrared blocking alarm device
- Night dog barking anti-theft reminder circuit
- Homemade anti-theft watchdog
- Car audio system anti-theft circuit
- stuttering correction circuit
- Ultrasonic blind pathfinder circuit
- Electric massager circuit
- Junction field effect transistor mixer circuit
- base amplitude modulation circuit
- Double gate field effect transistor high frequency amplifier circuit
- Wireless microphone circuit
- Power phase sequence display circuit
- Small current generator circuit
- Sine wave signal generator circuit
