H-bridge drive circuit working in two quadrants
Source: InternetPublisher:太白金星 Keywords: Drive circuit H-bridge drive BSP Updated: 2020/02/09
The safe reversal program should be as follows: first
change the PWM signal to zero level, delay it for a period of time to stop the motor, or detect and monitor the back
electromotive force After it reaches zero, change Fwd, and then start the motor. . For
loads such as fans and pumps, two-quadrant operation is more appropriate, as the acceleration performance and efficiency
are higher than four-quadrant operation.
The H-bridge structure shown in Figure 2-4
consists of four power switches and four freewheeling diodes. The characteristic of the bipolar mode is that two sets of switches on the diagonal line of the four bridge arms are respectively controlled,
VF, and VF, and one group is turned on or off at the same time, VF, and VF. As a group, they are also
turned on and off at the same time. At most one group is allowed to be turned on at any time. The simplest
control is that within a switching cycle, first the first group (VF, and VF.) is turned on, a forward voltage
is applied to both ends A and B of the motor , and then it changes to the second group (VF, and
VFa) conduction, a reverse voltage is applied across the motor. From this, the time share occupied by the two states
determines whether the average voltage is positive or negative, and whether the average current is forward or reverse. When
the two states are equal (1; 1), it is equivalent to the average voltage being zero and the motor stalling. In the bipolar
mode, there may be a problem of direct connection between the upper and lower bridge arms. For this reason,
a "dead zone" state is inserted between the two states , that is, a state in which all four bridge arms are turned off for a short period of time. Like the PWM control of the MC33030
, a dual-comparator window comparator is used to generate four-bridge arm control to
achieve bipolar PWM switching control with dead zone. Bipolar PWM control
is most commonly used in DC motor application-specific integrated circuits, such as the late UC3637,
L292, TAL955, etc.
- How to choose the right level of integration to meet motor design requirements?
- Use your smartphone to turn on/off the power in your home
- How to Make a Simple Chicken Incubator
- Tutorial for building a remote-controlled Arduino Air-Boat
- A simple door handle touch alarm circuit
- Motor automatic cycle control circuit
- Add one more component to improve the phase failure protection function
- Design and analysis of wire control circuit
- Design and manufacture of three-phase motor protection circuit
- Bicycle anti-theft alarm
- Voice controlled flash LED light circuit diagram
- strain sensor
- Analysis of rectifier circuit types and principles
- Agricultural temperature control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Varactor Diode Frequency Modulator
- ring amplitude modulation circuit
- Inductive feedback oscillator circuit
- Guest arrival signal recognition circuit
- Sawtooth wave generator circuit (2)
