Infrared light remote control switch circuit diagram
Source: InternetPublisher:明天见 Keywords: Remote control switch switch circuit diagram Updated: 2020/08/27
The infrared light remote control switch uses a pyroelectric infrared sensor as a human body proximity sensing device, so that the light controller can realize the function of "lights on when people come and lights off when people leave". It is especially suitable for hotels, offices, residential corridors and home use. .
The circuit of the infrared light remote control switch is as shown in the figure. It is mainly composed of pyroelectric infrared sensor, infrared processing integrated circuit S-01, control circuit and power supply. The integrated circuit IC 1 includes an amplifier, a comparator, a state controller, a delay, etc. inside. R2, RP3 and R3 connected outside IC1 are adjustment devices designed to automatically turn off the lights during the day. R3 is a photoresistor, and its resistance changes with light. During the day, its resistance is between a few hundred ohms and several thousand ohms, and at night it will increase to more than 1MΩ. By adjusting the resistance of RP1, pin ② of lC1 can output a high level when night falls and a low level after dawn. R6-R9 in the circuit are set up to determine the gain of the amplifier inside IC1. In addition, R11 and C10 external to IC1 are delay networks, and the delay is 1 minute.
![Click to enlarge](http://www.eeworld.com.cn/circuit/upload/cbd6ddcb214e3d0dae616dd11847949c/f0a23899d9207c33a2d5f89712ee1801.gif)
When the pyroelectric infrared sensor detects the infrared signal of the human body, it will output a weak electrical signal to lC. The ⒁ pin is amplified by the two-stage amplifier inside IC1, and then compared with the set reference voltage by the voltage comparator, and then outputs a high level. After delay processing, it is output by the ② pin of IC 1 to drive VT1 to make the relay K works, its contact K1 is connected to the power of the lamp, and the lamp is lit. When people leave, the lights will turn off automatically after 1 minute. This circuit also has the function of continuous triggering. When the lamp is on and lit, if a second trigger occurs, the delay will restart to keep the lamp on. If someone stays at the scene and does not leave, the light will continue to light up without going out.
- How to Build a Simple FM Radio Receiver on a Breadboard
- Methods to reduce mutual coupling between antenna elements
- Convenient and practical multifunctional wireless nursing assistance device
- Wireless doorbell production
- Homemade wireless voice transmitter for telephone
- MAX2360/MAX2362/MAX2364 I/Q 2000~1700 MHz/1000~800 MHz dual-band
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- rfPICl2C509AG/509AF ASK/FSK 480~310 MHz with 8-bit microcontroller transmitter
- MAX2900/2901/2902 BPSK/ASK/OOK 915/868 MHz Transmitters
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- Photoelectric remote control power switch circuit diagram
- Proximity switch circuit diagram of tca205a
- Short-time working touch switch circuit diagram
- Touch switch circuit diagram B
- Doppler microwave automatic switch circuit diagram
- Sound-activated infrared remote control switch circuit diagram
- Infrared receiving and decoding remote control switch circuit diagram
- Automatic cycle switch circuit diagram
- Multifunctional leakage protection switch circuit diagram
