Dual flashing string circuit (2)
Source: InternetPublisher:王达业 Keywords: BSP thyristor DC power supply Updated: 2020/04/13
It is a general-purpose flashing light string controller controlled by a unidirectional thyristor
. The diodes VTI and VT2 are
connected to a self-contained oscillator. After power is turned on, VT1 and VI12 take turns to turn on and off alternately. When
VT1 is turned on and
VT2
is turned off, the DC power
is injected into the door panel of the one-
way
thyristor VT3
through R; ED1 goes out, VT3 loses
trigger current and turns off, and E1
goes out. At the same time, the DC power is injected into the f J pole of the unidirectional thyristor VF4 through
R, I:D2 , so that V D4 turns on the light string E2 and lights up, so the curved
light strings El and F:2 alternately flicker, light up and turn off. LED tube I. F:r)l and LFD2 play an indicating role,
and the bright flame of "J" is synchronized with the light string {:l and F2. The RP changes the oscillation frequency of the white-excited multivibrator, so
the lamp can be half-lit. The cross frequency.
MCRI is used for VT3 and VT4..-S type and other small plastic-encapsulated single BJ thyristors. f. It is required to use (:1-1H
400V polypropylene capacitors and other non-component components. Five special requirements.
- A white light LED power outage emergency light
- Circuit diagram of game score display using 7-segment LED
- USB powered portable light
- Resistor value selection circuit
- Colorimeter circuit
- Desk lamp dimming soft switch circuit
- Two-way electronic music doorbell circuit
- Fluorescent lamp electronic ballast circuit 11
- Photoelectric adjustment circuit
- Bedside lamp controller circuit
- strain sensor
- Excellent performance household inverter power supply circuit
- stuttering correction circuit
- Smoking Cessation Circuit
- Electronic anti-asthma circuit
- Agricultural spraying and insecticide control circuit
- ring amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- OTL low frequency power amplifier circuit
- Color display circuit
