Light-controlled street light circuit using TWH8778 (2)
Source: InternetPublisher:拿铁三分糖 Keywords: Light controlled street light BSP Updated: 2020/05/02
It is a light-controlled automatic street light made of TWH8778 power switch integrated circuit. Its circuit is relatively
simple and its power is very good. 220V AC power is rectified by VDl-~VD-1, R. Voltage reduction and current limiting 'VS1 stable cooking
outputs 12V DC voltage for powering the TWH8778 integrated circuit. During the day, the resistance
of
the photoresistor RP is much smaller than R
when exposed to natural light .
The level of pin ⑤ of the TWH8778 control terminal is lower than
1 6V. The internal electronic meter is disconnected, the transistor
VT is in the off state, and the light E does not light up. When the light goes off and turns black in the evening
, the RI_ resistance begins to increase, causing the
level of pin ⑤ of TWH8778 to rise. When it rises to 1_6V, the electronic switch inside the integrated block is turned on, that is, pin ①
is connected to pins ② and ③, and the thyristor VT post R. The forward trigger current amplitude is obtained and turned on, and the street lamp E is energized and emits light. If you want to adjust the light control sensitivity of the fU circuit, you can appropriately change the resistance value
of resistor R. The function of the voltage regulator tube vs
is to ensure that the voltage applied to the fifth pin of TWiIB778 does not exceed 3V when it becomes completely dark to ensure
the safety of the integrated circuit and not be damaged.
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- DIY a hat with a programmable LED display
- LED Flasher circuit using 2 transistors for LED switching
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Use NE555 to make a lighting and sound changing circuit
- Simple electronic doorbell circuit
- One of the bead-type emergency light circuits
- Desk lamp dimming soft switch circuit
- Electronic music dimming desk lamp circuit
- Fluorescent dimming circuit (1)
- Set timing circuit when power is on
- Agricultural temperature control circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland irrigation automatic control circuit b
- Junction field effect transistor mixer circuit
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
