Light-controlled street light circuit using TWH8778 (1)
Source: InternetPublisher:念慈菴 Keywords: Light controlled street light BSP Updated: 2021/11/26
It is an
automatic street light composed of
TWf18778 power switch integrated circuit . Its
circuit working process is as follows: F: During the day,
the photoresistor RP
shows low resistance when exposed to natural light! The plate tube VT
is turned on, and its collector outputs low level .
The control terminal of TWFI8778, i.e. the fifth pin iLl, is about 0 2V. The internal power supply rr is turned off and the relay K does not
act . The J lamp F does not light up: at night. RI. High voltage will appear under no light irradiation, VT is cut off, and
the level of pin ⑤ of TWH8778 is determined by the ruler. The partial voltage with R is about
18V, and the large door opening level
is 1W, so the electronic switch on the integrated block f^J
is closed, that is, the ① pin is connected to the ② and ③
pins, the relay K draws the base, and
the closing contact k is established. - 1 is closed, the circuit ¨E
is energized and glows.
vs, bar and R; it forms a simple
voltage stabilizing source, providing 10V stability for VT
J. operating voltage, plus the absorption network
R, and G, so the circuit works very reliably. RP is the light control sensitivity adjustment potentiometer. Adjusting RP can make the street lamp start
to light up
under the appropriate illumination .
- DIY a hat with a programmable LED display
- Measurement and analysis of automatic emergency lighting circuit
- DCD-1240 multifunctional rechargeable lighting
- Low cost LED automatic emergency light circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Lighting sound-activated switch circuit using thyristors Part 3
- Mains undervoltage and overvoltage protection circuit 2
- Large light emitting diode display circuit
- Mains undervoltage and overvoltage alarm circuit 2
- Four color light circuit
- Set timing circuit when power is on
- Agricultural temperature control circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland irrigation automatic control circuit b
- Junction field effect transistor mixer circuit
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
