Light controlled street light circuit using TWH8751
Source: InternetPublisher:走马观花 Keywords: Light controlled street light BSP Updated: 2020/11/14
A light-screw automatic street light composed of TWH87sl power switch integrated circuit
connects the input pin ① of TWH8751 to the positive terminal of the power supply, so the output pin @ status is controlled by the strobe terminal, that is, the level of pin ②
. During the day, RP shows low resistance when exposed to natural light. The strobe pin ② is high level , so the output
pin ④ is also high level. Relay K does not operate and street light E does not light up. Night, Rl. When there is no light
, the resistance is high, the ② pin of the strobe terminal is low level, the Darlington tube inside TWH8751 is turned on, the ④ pin is low level , the relay
K is closed, its moving contact kl is closed, and the street lamp E is energized. glow.
Adjusting the RP resistance value can adjust the light control sensitivity of the circuit. R. , c. In order to interfere with the pulse absorption circuit, it can eliminate the influence of short-term light on the circuit
at night . T Dingchuan 220V:121:, jVA small high-quality power transformer. According to the load
size, select the appropriate I_ relay with a voltage of 12V, such as JZ ('22F, DC12V type, etc.).
- Blinking LED circuit diagram based on LDR and resistor
- Power outage emergency lighting
- SC3071 touch step dimming light circuit
- Lighting sound-activated switch circuit using thyristors Part 3
- Motor speed photoelectric control circuit
- Simple light-controlled street light circuit (7)
- Electronic music dimming desk lamp circuit
- Gas and smoke alarm circuits with intermittent alarms
- Seven-way flashing light string circuit
- Four color light circuit
- Set timing circuit when power is on
- Agricultural temperature control circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland irrigation automatic control circuit b
- Junction field effect transistor mixer circuit
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
