Simple light-controlled street light circuit (4)
Source: InternetPublisher:黄土马家 Keywords: Light controlled street light BSP Updated: 2020/09/26
It is a light-controlled street light circuit made of general thyristors . And it also adopts the two-wire connection method,
so the installation is relatively simple.
During the day, the photoresistor R1_ is exposed to natural light. RT. It shows low resistance, and after dividing the voltage with R,
the obtained voltage is lower than the reversal voltage of the directional trigger diode VDH, the rectangular thyristor VTH is disconnected, and the voltage
E does not light up. When night falls, the voltage on RI gradually increases. When it is higher than the switching voltage of VDH,
VT11 is turned on and the street lamp F lights up. This circuit also has a soft start process, which is beneficial to extending the service life of the bulb
. Increasing or decreasing the resistance of R can change the light control sensitivity of the circuit , but generally there is no need to adjust it.
VDH can use bidirectional trigger diodes with a folding voltage of 26-40V, such as 2CTS, DH3 type, etc.
VTH can use 3A/600V thyristors. When
a radiator with sufficient area is installed, the maximum load power is less
than 500w.
- Build a Bluetooth-controlled wireless scoreboard
- IR2153 emergency fluorescent lamp circuit diagram
- Six LED stereo VU display circuit built with IC LM3915
- Lighting lamp voltage stabilizing circuit (2)
- Corridor automatic light-off device
- Colorimeter circuit
- AC and DC dual-purpose flash light
- Three-way music lantern circuit
- Temperature control alarm circuit
- Electronic rapid starter for fluorescent lamps
- Set timing circuit when power is on
- Agricultural temperature control circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland irrigation automatic control circuit b
- Junction field effect transistor mixer circuit
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
