Simple light-controlled street light circuit (3)
Source: InternetPublisher:黄土马家 Keywords: Light control street light Updated: 2021/11/11
This is a simple JT controlled street light circuit that uses one-way gate tubes. VDP is a photosensitive
diode. During the day, it shows low resistance , with a resistance value ≤ ikfl. The transistor VT2 is cut off, and the thyristor VT1 is turned off because there is no
trigger current in the gate, and the street light E does not light up. At night, VL shows high resistance when exposed to no light , with a resistance value ≥
iO. kfl, VT2 is turned on, and the emitter can output a positive trigger current to flow through the f J pole of vri, causing VTL to turn on and
F to light up. The thick junction RP can make the circuit light up the lamp E when the illumination F needs to be turned on. This circuit is equipped with
a voltage regulator vS to make the circuit operation more stable and reliable. When installing the circuit
, the photosensitive diode VDP should also
be careful to avoid the light of the lamp E itself.
- TEC laser diode driver circuit
- Audio level LED and digital dual display circuit
- LED Signage with RS232 Port Operation Guide
- Laser detection and indicating device system circuit design
- Design and production of rain control and light control timing controller based on P87LPC764
- Infrared remote control device circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Gas flameout alarm circuit
- Electronic music dimming desk lamp circuit
- Touch/wireless remote control dimmer light circuit diagram
- Light control street light circuit
- Light-controlled street light circuit using TWH8778 (2)
- Light-controlled street light circuit using NE555 (2)
- Light-controlled street light circuit using NE555 (1)
- Simple light-controlled street light circuit (5)
- Simple light-controlled street light circuit (4)
- Simple light-controlled street light circuit (3)
- Light-controlled street light circuit composed of integrated circuits
- Light-controlled street light circuit composed of unidirectional thyristors
- Light-controlled street light automatic switch circuit
