Pyroelectric infrared induction automatic light circuit (7)
Source: InternetPublisher:红水杯 Keywords: Infrared induction automatic light pyroelectric infrared Updated: 2021/01/17
An induction automatic light made of RDP-18 pyroelectric infrared sensing module . RDP-IS is
a novel module produced by Zhejiang Huiniu City/Nan Radio Factory. It integrates all pyroelectric infrared control circuits and
JiIR sensing It has a head and Fresnel lens, so the mouth path is very simple.
The RDP-18 module has 6 external colored leads. ①The red lead is the power terminal, and the voltage
range is 6-9V. ②The yellow lead is an external delay capacitor. When the yellow line is suspended, the module is triggered and
the output pulse width is 30s predetermined by the circuit. If a capacitor is connected in parallel between the yellow line and the green line,
the output , that is, the output delay time increases. ③The green line is the external delay resistor terminal. When the yellow and green lines lbJ are connected to
a delay capacitor, a delay resistor needs to be added between the green line and ground. The output pulse width is determined by the external delay
capacitor and delay resistor values: If the fluorine is connected to the yellow and green wires of the module, once the module is triggered,
there will be output at the output end until the power is cut off
. ④The white line is the indication output
terminal, u J can directly drive the light-
emitting diode. ⑤The blue line is the output terminal.
Since the module has an open-collector output inside
and a pull-down current sink output
, it can directly drive small relays
and other tasks. ⑥The black wire is the ground
terminal, connected to the negative pole of the power supply.
Figure 80 only uses RDP-18
module f. One lead is blue and black
, and the other three leads are left floating. 2 20V AC power is rectified by VD2--VD5, R. Buck, vs
stabilized and C filter output 6V DC voltage for RDP-18. When someone enters the detection range of the module,
the blue line of its output terminal inputs a pull-down current sink to turn on VT1. The thyristor VT2 obtains a positive trigger current and turns on
, and the lamp E lights up. As long as someone continues to move, the lights can be on and off. After the person leaves, Can
will turn off itself after a delay of 30 seconds. This circuit is not equipped with a light control circuit , so it can be fully operated. It is especially suitable
for use in dark stairwells or storage areas where lights need to be turned on during the day.
- One-digit display
- Practical sensitive light-controlled switch circuit diagram
- Infrared remote control device circuit
- Use NE555 to make a touch self-extinguishing table lamp
- SC3071 touch step dimming light circuit
- Gas flameout alarm circuit
- WT8089 holiday lights ASIC
- Two-way electronic music doorbell circuit
- Fluorescent lamp electronic ballast circuit 11
- Seven-way flashing light string circuit
- Pyroelectric infrared light automatic control circuit
- OT0001 pyroelectric infrared remote control application circuit
- Bathroom automatic light circuit
- Infrared reflective automatic light circuit
- Microwave radar detection automatic light circuit (3)
- Pyroelectric infrared induction automatic light circuit (7)
- Pyroelectric infrared induction automatic light circuit (5)
- Use NE555 to make light-controlled automatic lights
- HT-7605 (alarm, lighting and industrial control) pyroelectric infrared receiving control circuit
- Application circuit of pyroelectric infrared sensor in human body detector
