Discrete component sound and light control stair delay switch circuit (1)
Source: InternetPublisher:fish001 Keywords: Discrete components switching circuits light control BSP Updated: 2020/05/17
-A real sound and light stair delay lighting +F switch circuit. Its special feature is that during the day, the lights
automatically turn off and turn on: in the evening, as long as there are people walking on the stairs or there are people talking, the lights will light up.
After a delay of a few seconds, the lights will automatically go out. The circuit adopts the "= line system" The connection method does not require only two connecting terminals,
which can be connected instead of ordinary connectors. 1nj There is no need to change the original photo route.
220V
AC interpretation bulb E,
VDl - VD4 rectifier , the positive
anode voltage
is formed between the
anode and cathode of
the thyristor VT4 to form
the main circuit of
the light switch . The control
circuit is composed of Vl l - wi 3 and other devices, and its T_ is used as the power supply to white R, and the voltage reduction and current limiting, Vnj isolation,
Vs voltage stabilization and (j filtering) are in ((, the curve terminal can obtain about 10V Stable DC voltage. During the day, the photoresistor
RI has a low resistance when exposed to natural light, so that V2 and VT3 cannot enter the conductive state, so the lamp E will not
light up . At night, R1 shows high resistance, thereby eliminating the need for VT2 , VT3 is blocked. At this time, if someone is walking or talking in the stairway
, the footsteps or conversation will be picked up by the microphone H and converted into an electrical signal, which is
amplified by (1- through VT1, and the amplified signal is passed through ( j coupling. The positive half cycle of the H signal can make vD2 conductive, and VT3
also conducts one after another. (, the stored charge is quickly charged to (j through VTS, VD6, and the thyristor wn
is opened , and the lamp E is energized and emits light. After eight steps, (, the stored charge passes through R. The gate of V1 is discharged, and
VT4 can still be kept on, so the light will go out immediately. Until C, after the charge wall is discharged, VT4 loses gate
triggering Current, when the alternating current crosses zero, VT4 is turned off and the lamp E goes out. The circuit delay time should be determined by
/ s, (: The value is determined according to the need.
VT-i should select the trigger current Smaller 0 8 ~ 1A, 400 -6 (] 0V coin-oriented crystal VI arm, such as
VILR100-S, 2N6ii5, ljT1 69, etc. I<l, the larger the difference between the light resistance and the dark resistance, the better
MG44, M(;45) and other photosensitive electric speakers. Small electret condenser microphones with higher sensitivity should be used, such as
LRZ, 113F type, etc. This component will be studied many times by Benlu. The requirements are the same, so I won’t elaborate on Shui Ran.
- Experiment on realizing photoelectric alarm using photosensitive devices
- Use NE555 to make a lighting and sound changing circuit
- Solar battery and charging circuit
- Infrared remote control device circuit
- Use NE555 to make a touch self-extinguishing table lamp
- One of the bead-type emergency light circuits
- Large light emitting diode display circuit
- Digital display multi-function thermometer circuit
- 6-digit cathode fluorescent triode display circuit
- Touch lighting switch circuit three
- Analysis of rectifier circuit types and principles
- Physiotherapy ventilator circuit
- Egg heating control circuit
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit a
- DC ammeter
- Voltage-controlled voltage source second-order active low-pass filter circuit
- superheterodyne radio circuit
- High and low frequency signal generator circuit
- Motorcycle flash light circuit
