Delay lamp circuit using application specific integrated circuit
Source: InternetPublisher:JFET Keywords: Application specific integrated circuit BSP Updated: 2020/06/01
A delay lamp made of Sanji light control special integrated circuit , the circuit is very simple. Fall in. H L2102 integrated circuit is a
lamp timing
integrated circuit
produced by Wuxi Aixinke Microelectronics Co., Ltd. (lmp, ¨'WV.7W. wx.sjc.tⅡn). The timing time can be from seconds to minutes. , well can be determined at will.
HL2102 adopts standard DIP 8 package. The functions of each pin are shown in Table 3.1. The power supply voltage range is 2-6V.
Figure 85 can be used for lighting when you get up temporarily at night
. When using it, just press the button
switch SH iLi and the light F will light up.
After a delay of tens of seconds, the light will go out in white. During
the period when the light is on, if SB is pressed again,
the light F can be turned off.
Since the delay time of this circuit is short,
the I{ and ^ terminals of the integrated block HI.2102,
that is, the ⑥ and ⑦ pins must be connected in parallel.
The timing capacitor H needs to adjust
the resistance , and then the timing can be obtained from several seconds to several seconds. Ten seconds timer. If you require a higher K timing, you can connect a timing capacitor
in parallel to the ⑥ and ⑦ pins of HU102 . The T power supply of I11,2102 is composed of capacitor [1=
step-down, vr] half-wave rectification, vs stabilization and C. Obtained by filtering.
- A simple magnetic switch circuit sharing
- Analysis of the working principle of car garage door lights
- Servo motor pin diagram/working principle/application
- How to remotely control devices using ESP8266 and LPC2148
- Peripheral circuit of automotive motor controller power supply chip
- How can we make the robot move precisely on a predefined path?
- Squirrel cage asynchronous motor reverse braking control circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Design and production of wireless multi-location control switch circuit
- Home wireless burglar alarm circuit
- Electric massager circuit
- Pulse therapy circuit
- Inpatient pager circuit
- Greenhouse temperature control circuit
- Farmland drainage automatic control circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Audio function generator composed of ICL8038
- Second-order active band-stop filter circuit
- High and low frequency signal generator circuit
- Sawtooth wave generator circuit (1)
