Use LM386 to make two-color voice-controlled music lanterns
Source: InternetPublisher:小胖友 Keywords: Voice control LM386 music lantern Updated: 2020/09/01
The festival light controller circuit made with SK-12P integrated circuit
is shown in Figure 2-88. VDI, VD2, Rl, and C2 form a resistor step-down voltage stabilizing rectifier circuit, which outputs about 5v DC voltage for
the integrated block. Since pin 1 of the trigger terminal of the chip is connected to pin 12 at high level, after the power is turned on, the seven drive output
terminals, namely pins 2, 3, 4, 5, 7, 8, and 9, will automatically output high level in a cycle according to the program. , the seven groups of colored lanterns are illuminated in sequence in six pattern
control modes . With the continuous conversion of the six pattern control modes , the flashing patterns of the lanterns continue to alternate,
producing a magical dreamy effect.
- Making a photometer with light measuring function
- Laser detection and indicating device system circuit design
- Driving circuit for driving light-emitting diodes by IR53HD420
- battery charging circuit
- "OR" logic element configuration circuit
- Seven-way flashing light string circuit
- Incandescent lamp dimming circuit using thyristor part 4a
- Fluorescent dimming circuit (1)
- 6-digit cathode fluorescent triode display circuit
- Night target display circuit diagram
- Transistor voice control amplifier circuit
- Practical amplifier circuit consisting of operational amplifier LM386 e
- Voice-activated music lantern circuit (2)
- Practical voice-controlled music lantern (2)
- SK-6 voice control circuit
- Voice controlled running water music lantern circuit
- Record player ceramic phono amplifier circuit using LM386
- Clever use of LM386 as audio oscillator circuit diagram
- Clever use of LM386 as a multi-purpose radio circuit diagram
- Clever use of LM386 as BTL amplifier circuit diagram
