Use LM386 to make voice-controlled music lanterns
Source: InternetPublisher:aytwartoofyoroo Keywords: Voice control LM386 music lantern Updated: 2020/04/18
VD1, VD2, C1 and C2 form a simple capacitor step-down half-wave rectification and voltage stabilizing circuit, which outputs a DC
voltage of about 12V to power the integrated block LM386. The piezoelectric ceramic piece B connected to pin 3 of the non-inverting input terminal of LM386
receives the environmental
sound wave signal and converts it into the corresponding electrical signal. After amplification by the internal circuit of the integrated block, it is output from pin 5 and can be driven in both directions by C4 and
T. The silicon-controlled VS makes the conduction angle of VS change with the strength of the signal picked up by B, so the colored light string H can flash and light up with the strength of
the ambient sound wave signal .
- Audio level LED and digital dual display circuit
- Fire safety evacuation emergency signs
- Circuit diagram of game score display using 7-segment LED
- Blinking LED circuit diagram based on LDR and resistor
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Use NE555 to make a lighting and sound changing circuit
- Driving circuit for driving light-emitting diodes by IR53HD420
- Resistor value selection circuit
- Lighting audio control circuit
- Fluorescent dimming circuit (1)
- Monolithic radio circuit composed of audio power amplifier integrated circuit
- Transistor voice control amplifier circuit
- Internal circuit principle of LM386
- Use NE555 to create touch and voice-controlled dual-function delay lights
- Use LC172 to make novel voice-controlled music lanterns
- Voice controlled running water music lantern circuit
- LM386 audio IC amplifier circuit diagram
- Clever use of LM386 as audio oscillator circuit diagram
- Clever use of LM386 as music lantern controller circuit diagram
- Clever use of LM386 as light control relay circuit diagram
