Make a bedside delay lamp with CD
Source: InternetPublisher:黄土马家 Keywords: switch transistor Updated: 2021/11/21
In the figure, inverters I, II, R1, R2, CI and SB form a bistable trigger switch . Every time switch SB is pressed,
the output level of inverter II changes once. R3, C2, VD1 and inverting noise ⅡI, Ⅳ form a monostable delay circuit. Adjusting
the value of R3 or C2 can change the delay time of the circuit. Inverters V and VI are used in parallel to increase their driving capability.
The transistor VT and the peripheral resistor form a thyristor vs zero-crossing trigger circuit. When vs is on, the lamp H lights up: when vs is off,
the lamp H goes out. The 220V AC mains power is stepped down by resistor R8, rectified by diodes VD4 and VD5, and stabilized by VD6 to output a stable
6V DC voltage for use by the entire circuit.
- Making a photometer with light measuring function
- Design and production of rain control and light control timing controller based on P87LPC764
- Design and production of a practical electronic counting device
- battery charging circuit
- "OR" logic element configuration circuit
- 4-digit incandescent lamp display circuit
- Mains undervoltage and overvoltage protection circuit 2
- Telephone theft automatic notification device circuit diagram
- Frost alarm circuit
- Fluorescent dimming circuit (1)
- Color changing flash light principle circuit diagram
- Composite piped
- Transistor time relay circuit 5a
- Simple second pulse source circuit 2
- Improved multivibrator circuit c
- Soft start regulated power supply circuit 4
- Stabilized power supply circuit adjusted from zero
- 20V, 500mA regulated power supply circuit
- One of the anti-theft alarm circuits with warning wires
- One of the boiling water alarm circuits
