Improved multivibrator circuit c
Source: InternetPublisher:笑流年 Keywords: multivibrator oscillator circuit transistor diode Updated: 2020/12/02
The circuit is shown in Figure 15-40. Figure (a): R] and R2 are 15~18kn, Cl and C2 are 0.01~10"F.
Figure (b): Oscillation frequency, up to 2~5MHz, is adjusted by potentiometer RP. Figure (c) Connection The diode
can prevent the two triodes from saturating at the same time and stopping the vibration.
- An article explains the working principle of the Wheatstone bridge
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- In-depth analysis of energy losses in oscillation frequencies
- How to read resistor color codes? Resistor color codes illustrated
- Simple Wired Spy Bug Circuit Built Based on IC741
- Structural diagram and function of sliding resistor
- Make a simple AM radio with digital circuit
- LED lights that “drain” battery power
- LED Bicycle Lights
- 3V-5V level conversion circuit diagram
- A single-section transistor performance test circuit
- M50560 infrared transmitter circuit
- Composite pipe c
- Rechargeable time relay circuit 2
- Improved multivibrator circuit c
- Transistor reference basic bias circuit - fixed bias
- One of the water full alarm circuits
- output circuit
- Automatic water supply control circuit 2 for simultaneous monitoring of water tower and reservoir
