Color changing flash light principle circuit diagram
Source: InternetPublisher:难得正经 Keywords: Transistor power display power supply Updated: 2021/10/04
The collectors of the two transistors of the multivibrator are connected to light-emitting tubes respectively, and the light-emitting tubes can flash alternately according to the period of the multivibrator. This circuit has a wide range of uses and can be used for home decoration, etc.!
How the circuit works
This circuit uses high-gain pnp type germanium tubes vt3 and vt4 to form a multivibrator. There are two stages of inverters connected end to end. Capacitors c3 and c4 are used to couple the stages. Its working period is 1s!
Component selection and debugging
The transistor should choose 9012 or 9015 with a collector current greater than 50ma, and the light-emitting tube should choose a tube with high brightness!
If you want to change the flashing speed, you can adjust the capacity of c3 and c4, or you can use fine adjustment to replace r3 and r4. After the strips are set, replace them with the corresponding resistors!
![Color changing flash light principle circuit diagram](http://www.eeworld.com.cn/circuit/upload/5fbf55dd83cec511f64e5a97df2aed6b/4696844cbf2718e9e72fbbb02684bc89.jpg)
- Introduction and principle analysis of switching regulated power supply
- Simple and practical LED lamp driving circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED rechargeable flashlight circuit diagram
- LNK304 non-isolated LED light string driver circuit
- Current/voltage conversion circuit using current converter
- An ultra-low output voltage regulator
- Constant current charger using light emitting diode as voltage regulator
- Design of electric vehicle charger
- Practical constant current charger-----Constant current charger
- Detailed explanation of the working principle of linear regulated power supply
- Six common constant current source circuit diagrams and analysis
- H-bridge drive circuit schematic diagram and enable control and direction logic
- 3V-5V level conversion circuit diagram
- Wireless microphone circuit diagram composed of 9018 triode
- White noise electronic lullaby circuit diagram
- Composite complementary symmetrical push-pull output stage circuit
- Old 20W electronic ballast circuit diagram
- 24V, 500mA regulated power supply circuit
- Water full alarm circuit 2
