Roadblock flashing warning light circuit (4)
Source: InternetPublisher:同住地球村 Keywords: BSP supply voltage Updated: 2021/06/14
It is a battery-powered roadblock flashing warning light that can be
installed on local roads with AC power supply for roadblock warning purposes. hF555 and RP1, RP2, (., RI. form a light-controlled self-excited multivibrator . During the day, RJ is exposed to light and shows low resistance. NF: The level
of the ④ pin of the forced reset terminal of 555 is less than 0 4V.
NF.J55 The ③ pin of the forced reset output terminal is always low level. Vll and wT2 are cut off, and the alarm light E lights up.
At night RI, when there is no light, the resistance is high, and the voltage of 4 and RP2 makes the level of pin ④ rise. When the circuit is at 0 tv
, the blockage on the circuit is released and the circuit starts to oscillate.
Principle: The ② pin of NE5 5 5 is low
level. At this time, the circuit is set, ③ pin outputs
high level , and ③ pin Through RP1 to C, the photoelectric, so that (,,
the voltage at the bend terminal, that is, the level of pin ⑥ is constant). When it rises
to 2,73 of the power supply voltage , the circuit breaker resets, pin ③
outputs low level, then c, Discharge to pin ③ through RP1
, causing the voltage at terminal C, that is, the level of pin ②, to continuously
decrease. When it drops to 1/3 of the power supply voltage , the circuit
cross is set to 䗗, and pin ③ suddenly changes to high fU level, and the cross passes through
RP1 Charge to L... and it will oscillate over and over again
. Therefore, the gap between pin ③ outputs high level and low level. When pin ③ outputs high level, VT1 and VT2 are turned on, and
E is lit; when pin ③ outputs high level, When the input is low , VT1 and VT2 are cut off, and F is extinguished. It can be seen that as the oscillation of the time circuit NE555 proceeds, the warning light E will continue to flash and glow.
The frequency of the flashing
can be changed by RPl. , adjust the light control sensitivity of RP2 to strip the whole circuit so that the circuit can operate normally under appropriate illumination
R1. Can be H1 MC, 45 type and other photoresistors. VT2 requires the use of NPN type high-power two-tube tubes. .R
uses automotive 12V light bulbs, and a red lampshade needs to be installed on the outside. G is a 12V battery. Other components have no special
requirements.
- Build a Bluetooth-controlled wireless scoreboard
- A white light LED power outage emergency light
- Measurement and analysis of automatic emergency lighting circuit
- Blinking LED circuit diagram based on LDR and resistor
- Design and production of rain control and light control timing controller based on P87LPC764
- Use NE555 to make a lighting and sound changing circuit
- Chandelier brightness controller circuit using thyristor
- Electronic rapid starter for fluorescent lamps
- SH-803R holiday lights ASIC
- Mains undervoltage and overvoltage alarm circuit 2
- Motor overcurrent protection circuit
- Excellent performance household inverter power supply circuit
- Egg warming circuit
- Rural vegetable greenhouse lighting circuit
- Junction field effect transistor mixer circuit
- Varactor Diode Frequency Modulator
- Wien bridge oscillator circuit
- Crabo oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Digital stopwatch display circuit
