Motor winding judgment circuit
Source: InternetPublisher:D先生 Keywords: power outage motor winding Updated: 2021/08/26
(1) In-phase winding judgment: Connect two batteries in series, then
connect one pole of the light-emitting diode according to polarity, the other pole is connected to any tap of the motor, and the remaining
taps are in contact with the other pole of the battery. Touch, the light-emitting diode is the same-phase winding.
(2) Determine the beginning and end of the winding: first connect one end of any two-phase winding of the motor
, and connect the
other two ends to the two poles of the light-emitting diode. Connect one end of the remaining phase winding to the negative pole of the battery
, and the other end to the other end of the battery. Electrode touch. At the moment of switching on, if
the LED lights up, then the positive electrode of the battery, the negative electrode of the LED,
the other end of the winding to which the positive electrode of the LED is connected, and the first or last end of the winding are all identified at once. If it does not light up, you can
change the battery electrode or winding connector and try again. If the LED does not
light up no matter how you change the connections, you should check the battery, LED and each connector until it lights up.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Car ice warning circuit sharing
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- A small improvement to the temperature and water level indicator alarm
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Add one more component to improve the phase failure protection function
- Design and production of radio remote control fan stepless speed regulator
- Design and analysis of a four-bit remote control component capable of remote reset
- Homemade anti-theft watchdog
- 13 examples of electric drag control circuit diagram
- Multi-channel patrol detection control circuit b
- Digital camera flash control circuit
- Electromagnet control circuit
- Table printing machine control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- Typical operation display circuit
- Electric heater temperature detection control circuit
- Typical electronic volume control circuit
- Button type electronic volume control circuit
