Three-phase motor winding head and tail speed judgment circuit
Source: InternetPublisher:newrudeman Keywords: Three-phase motor winding Updated: 2020/01/03
Circuit working principle: aa', bb' and cc' in the figure are three-phase windings respectively. Double throw
switch K1-1 to K1-4. Both are turned to the left, that is, "l" and "2" of the switch are connected. At this time,
aa' and bb' are connected in series on the secondary side of transformer T, and the 6.3 V small bulb H is connected in parallel to both
ends of cc'. If a and b are connected to the heads or tails of windings aa' and 66', then when
button AN is pressed, an induced current will be generated in winding ce' and H will light up. On the contrary, if a and b are not
at the same end, the magnetic fields generated by aa' and bb' will cancel each other, there will be no induced current in cc', and
H will not light up. Based on this, we found out the names of aa' and bb'.
- Model rocket launch controller circuit
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Design of an autonomous plant watering system using ATtiny85
- Build a glove-controlled robotic arm
- How to build a simple tachometer using an infrared reflectance sensor
- DIY an electromagnetic levitation device
- Perform surgery on the speaker protection circuit
- Motor automatic cycle control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Homemade anti-theft watchdog
- Multi-channel patrol detection control circuit a
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Photoelectric tracking control circuit
- Three-phase stepper motor control circuit
- CPU input and output and memory control circuit
- Galanz rice cooker control circuit
- Three-phase motor forward and reverse control substitution circuit
- Three-phase motor phase loss automatic protection circuit
- Three-phase motor phase sequence and phase failure protection circuit
- Wiring method for changing three-phase motor to single-phase operation_1
