Wide voltage stepper motor controller circuit
Source: InternetPublisher:toothache Keywords: Wide voltage controller circuit stepper motor motor controller Updated: 2021/07/29
Working principle of the circuit: As can be seen from the figure, IC, (LF356) wide-band operational amplifier
constitutes a square wave clock signal generator, and the potentiometer RP. It is used to adjust the oscillation frequency and adjust
the speed of the stepper motor . The IC2 (4017) decimal counter is a step signal forming
circuit. As the rising edge of the clock pulse signal at the 14-pin input terminal arrives, the
Qo~Q9 output terminals of the counter rise to high level in sequence. VD,, VD:,R, and VD3, VD. ,
R6 constitutes two OR gate output circuits, which respectively send out the same frequency and 90 phase difference. The
"I" and "Q" step control signals. "I" is the initial phase signal, "Q" is the phase shift by
90. Signal.
- A simple magnetic switch circuit sharing
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Motor self-starting circuit
- Simple phase failure protection circuit composed of intermediate relay
- Design and production of radio remote control fan stepless speed regulator
- Hydraulic control circuit design and analysis
- Light-controlled circuit design and analysis
- Design and analysis of voice control circuit
- Electric vehicle battery charging protection circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Multiple cam controller circuit
- Photoelectric controller circuit with anti-interference capability
- Wide voltage stepper motor controller circuit
- Computer temperature controller circuit
- Color light ring flash controller circuit
- Industrial four-way programmable controller circuit
- Multifunctional password controller circuit b
- Voice control light controller circuit
- DC detection automatic watering controller circuit
- Multifunctional light touch electric fan controller circuit
