Power outage emergency lights (3)
Source: InternetPublisher:sigma Keywords: Emergency lights BSP triode Updated: 2020/04/30
The transistor VT forms a typical inductive three-point oscillator with a frequency of 100 kHz. The capacitor C2 is a positive feedback capacitor.
Its function is to feed back part of the energy of each inductor oscillation to the base circuit of the transistor VT for further amplification. After amplification,
the current flows from the collector The electrode output feeds back part of the energy to the base via the inductor L2 and capacitor C2. In this way, the circuit can
maintain oscillation over and over again. T is a step-up transformer. The high-frequency oscillation current is boosted by L3 and directly added to both ends of the fluorescent tube to make the tube
ignite and glow. Using a high frequency of 100kHz is beneficial to improving the luminous efficiency of fluorescent lamps. By adjusting the potentiometer RP,
the oscillation frequency can be fine-tuned, thereby achieving the purpose of adjusting the brightness of the lamp. R4 is a protective resistor to prevent the transistor
from being damaged due to excessive base current when RP is adjusted to zero .
When charging. The 220V alternating current is reduced and current limited by CI and R2, bridge rectified by VD1~VD4, and then charged to battery G through VD5
. LED is the charging indicator light. VD5 is a charging protection diode. When the battery G is sufficient, the diode VD5
is cut off due to the increase in negative electrode potential, and charging automatically stops, thus effectively preventing battery overcharging. Since the capacitor voltage reduction has a constant current
effect, the charging current is limited to less than 220 X2ⅡfCl, which is about 55mA.
- Audio level LED and digital dual display circuit
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- Design and production of rain control and light control timing controller based on P87LPC764
- Practical sensitive light-controlled switch circuit diagram
- One of the water full alarm circuits
- Lighting lamp voltage stabilizing circuit (2)
- Application circuit of CAT3606
- Seven-way flashing light string circuit
- Bedside lamp controller circuit
- 6-digit cathode fluorescent triode display circuit
- Voice controlled flash LED light circuit diagram
- Analysis of rectifier circuit types and principles
- Homemade disinfectant circuit
- Agricultural temperature control circuit
- Particle clogging alarm circuit of wheat seeder
- Simple AGC circuit in transistor radio
- Schiller oscillator circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Various signal generator circuits
