Light-controlled lighting using triac (2)
Source: InternetPublisher:失踪的猫 Keywords: Triac light controlled lighting trigger Updated: 2021/03/18
VDI, VD2, Cl and C2 form a simple
capacitor step-down semi-rectified power supply. After powering on,
a DC voltage of about 12V can be obtained at both ends of C2 for the light
control circuit. VT, VD3, R2, R3 and RP
form a light control circuit. During the day, the photosensitive diode VD3 has a low resistance
when exposed to light , and the VT base potential decreases, so the VT is cut off. The thyristor VS does not get the trigger voltage and is in
the off state. H does not light up. At night, VD3 has a high resistance without light exposure . The base potential of VT rises and VT is turned on,
which injects a forward trigger current into vs. Therefore, vs is turned on immediately and the lamp H lights up at full voltage. Adjusting the potentiometer RP can adjust
the base potential of the transistor VT, thereby adjusting the light control sensitivity.
- One-digit display
- Experiment on realizing photoelectric alarm using photosensitive devices
- TEC laser diode driver circuit
- Fire safety evacuation emergency signs
- DCD-1240 multifunctional rechargeable lighting
- LED Flasher circuit using 2 transistors for LED switching
- Design and production of digital number answering machine
- Infrared detection alarm
- Colorimeter circuit
- Automotive LED driver circuit diagram using LT3486
- Thyristor triggered interface circuit b
- Thyristor triggered interface circuit a
- TBY-753A type fast charging regulated power supply circuit diagram
- Zero trigger thyristor power adjustment circuit 3
- KJZ3 type three-phase half-controlled bridge trigger control circuit
- Zero trigger integrated circuit temperature control circuit three
- Automatic light control lighting circuit three
- Bidirectional thyristor stepless dimmer with light stabilizing function
- Triac zero-crossing trigger voltage regulator circuit
- Triac AC voltage regulator
