Zero trigger integrated circuit temperature control circuit three
Source: InternetPublisher:fish001 Keywords: trigger integrated circuit temperature control circuit Updated: 2020/03/14
It uses M5172L zero trigger integrated circuit . The temperature sensing element is a thermistor Rt with negative temperature coefficient
. Adjust the potentiometer RP to change the set temperature .
- Analysis of the working principle of car garage door lights
- Tutorial for building a remote-controlled Arduino Air-Boat
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- What is a RADAX motor?
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Squirrel cage asynchronous motor reverse braking control circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- An experimental model of an infrared radio alarm
- A novel and practical power line anti-theft and cutting alarm circuit
- Homemade disinfectant circuit
- Multi-channel patrol detection control circuit a
- Digital current loop control circuit
- Humidity detection box control circuit in greenhouse
- Temperature detection control circuit of electric hot water bottle
- Voltage servo motor and control circuit
- Inverter brightness control circuit
- Wide input range non-synchronous voltage mode control circuit
- Power supply circuit with multiple outputs (MAX1902)
- 35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
