Light controlled lighting using one-way thyristor
Source: InternetPublisher:常思一二 Keywords: SCR light-controlled lighting electric lamp rectifier Updated: 2020/12/23
RG is a photoresistor, which forms a voltage divider with the fixed resistor R. Its divided voltage value is rectified
by the diode VD and added to
the gate of the thyristor vs as the trigger voltage. During the day, RG is exposed to indoor natural light and
shows low resistance, and the partial voltage value is low, which is not enough to trigger the thyristor vs.
Therefore, vs is in the off state and the lamp H does not light up. When night falls
, RG has high resistance without light exposure, and its partial voltage value is relatively high. After being rectified by
VD , it is added to the door panel of vs, so that the lamp H is turned on quickly and the lamp
H lights up. When the lamp is in the glowing state, the current flowing through it is half-wave alternating current, and the lamp is in an under-voltage state, so the service life of the lamp is extremely long. Therefore, this circuit is very suitable for unmanned public walkway lighting.
- Circuit diagram of game score display using 7-segment LED
- Blinking LED circuit diagram based on LDR and resistor
- LED Flasher circuit using 2 transistors for LED switching
- Design and production of rain control and light control timing controller based on P87LPC764
- Musical doorbell without buttons
- Solar battery and charging circuit
- Driving circuit for driving light-emitting diodes by IR53HD420
- "OR" logic element configuration circuit
- Frost alarm circuit
- Fluorescent lamp electronic ballast circuit 11
- Rectifier spike absorption circuit
- KGDS type single-phase low temperature iron plated power supply circuit
- A new type of dimming SM9043 integrated circuit
- Triac two-tone dimmer (2)
- SH-809 Holiday Lights ASIC
- SCR control buzzer circuit
- Automatic light control lighting circuit three
- Thyristor pre-regulators for various power supplies
- SCR automatic charger circuit
