Novel delayed lights out lighting switch
Source: InternetPublisher:笑流年 Keywords: switch power supply Updated: 2020/10/07
When the switch S is closed, the positive half cycle of the alternating current passes through VDI and R
to turn on the thyristor vs. At the same time, both ends of the capacitor C are also filled with
charges. At this time, the positive half cycle of the alternating current supplies power to the bulb H through vs , and the negative half cycle
supplies power to the bulb H through the diode VD2, so the bulb H is powered at full voltage at this time. When the light is turned off, the switch S
is turned on , and the capacitor C is discharged through the resistor R. This
discharge current keeps the thyristor VS on, so
there is still a positive half-cycle current flowing through the bulb H, but because S
cuts off the VD2 power supply in the negative half-cycle circuit, so the bulb H
is in a half-voltage power supply state, and the bulb emits dim light. After about 1 minute
, the capacitor C is completely discharged. Due to the loss of gate
trigger current, the thyristor VS turns off when the alternating current crosses zero, and the bulb goes out.
- Making a photometer with light measuring function
- IR2153 emergency fluorescent lamp circuit diagram
- LED Flasher circuit using 2 transistors for LED switching
- Simple light-controlled street light circuit (7)
- Electronic music dimming desk lamp circuit
- Chandelier brightness controller circuit using thyristor
- Frost alarm circuit
- Temperature control alarm circuit
- Shock resistant soft start constant current LED lighting circuit
- Night target display circuit diagram
- Furnace door interlock switch control circuit
- Voice recording and playback circuit
- Power supply coupler-thyristor interface circuit a
- Incandescent lamp life extension circuit 6
- Power supply for sounder circuit
- 220V AC power supply LED lamp drive circuit diagram
- Dual power supply small power DC voltage stabilizing circuit without power transformer
- Audio powered noise limiter
- Single-phase power quantitative power supply circuit
- Timed AC power supply circuit diagram that supplies power for 0-1 hour
