220V AC power supply LED lamp drive circuit diagram
Source: InternetPublisher:兰博 Keywords: Power supply drive circuit diagram LED lights WIDTH Updated: 2021/02/21
In the circuit, C1, R1, varistor, L1, R2 form the primary filter circuit of the power supply, which can filter out the input instantaneous high voltage. C2, R2 form the step-down circuit, and C3, C4, L2, and the varistor form the rectified filter circuit. This circuit uses a double filter circuit, which can effectively protect the LED from being damaged by instantaneous high-voltage breakdown.
ck="window.open(this.src)" alt="Click to see larger image" />
- Delayed gradual lighting with protection function
- Resistor value selection circuit
- SC3071 touch step dimming light circuit
- Simple electronic doorbell circuit
- Remote anti-theft alarm
- Automotive LED driver circuit diagram using LT3486
- Seven-way flashing light string circuit
- Temperature control alarm circuit
- SH-803R holiday lights ASIC
- Reverse polarity drive circuit
- Solar LED light circuit
- LA4480 power amplifier circuit diagram
- AN7147 power amplifier circuit diagram
- Common double-tube energy-saving lamp circuit schematic diagram
- Subwoofer crossover amplifier circuit diagram
- CDll4CP logic block circuit diagram
- Electric bicycle Jiateng charger circuit diagram
- Field output circuit: TA8403 circuit diagram
- The ever-changing sound and light analog controller circuit 02
- MAX16834 driver LED circuit diagram
