Incandescent lamp life extension circuit 6
Source: InternetPublisher:司马缸砸光 Keywords: Incandescent lamp BSP powered Updated: 2021/03/05
(6) Incandescent lamp life extension circuit No. 6
The circuit is shown in Figure 2-34. This circuit also uses a two-level power supply mode
, with the first level being half wave and the second level being full wave. The 555 time base integrated
circuit A is used as the delay protection link. This circuit also has a function: when the grid phase voltage rises above 225V (can be
adjusted and set by the potentiometer RP), the circuit will automatically enter the protection state, reducing the light bulb to half-wave power supply ; and when the grid voltage returns
to normal , and automatically put into full pressure work.
- Example of LED AC drive circuit
- LED Signage with RS232 Port Operation Guide
- Design and production of digital number answering machine
- Low illumination amplifier circuit
- One of the water full alarm circuits
- Transistor storage time test circuit
- Lighting sound-activated switch circuit using thyristors Part 3
- Application circuit of CAT3606
- Seven-way flashing light string circuit
- 6-digit cathode fluorescent triode display circuit
- Motor overcurrent protection circuit
- Excellent performance household inverter power supply circuit
- Analysis of rectifier circuit types and principles
- Smoking Cessation Circuit
- Mixer built with analog multipliers
- Double detuned loop frequency discriminator circuit
- Varactor Diode Frequency Modulator
- Diode square rate detection circuit
- Wien bridge oscillator circuit
- Second-order active band-stop filter circuit
