Car wiper automatic controller circuit
Source: InternetPublisher:MartinFowler Keywords: automatic controller controller circuit recorder Updated: 2020/05/25
Working principle of the circuit: As can be seen from the figure, the electronic clock alarm switch S. Connect between relay
K and the positive terminal of the 12 V power supply, disassemble the recorder , and remove the two wires on the "automatic shutdown switch"
(solder the two removed wires together). One end of S2 is connected to K,
and the other end is connected to the negative pole of the 12 V power supply. The power supply for the 50 W amplifier and recorder
is supplied by a set of normally open contacts of relay K. Transformer T is a 220 V/5 W power transformer with a secondary of 9V. It provides a 12 V
power supply system
through VD, VD4 rectification and C filtering .
The night before, insert the tape into the tape recorder , press the "play
" button (close S2), and insert the signal cable into the corresponding jack of the amplifier.
- How to calculate the power loss of RS-485 transceiver THVD1550
- How to build a self-driving drone
- How to build an electric vehicle EV charger
- Ray detection circuit
- LJ2 series transistor proximity switch principle circuit diagram
- Catillac luggage compartment opening circuit diagram
- Enhanced password lock circuit using AE1169
- Smart transmitter circuit diagram with hart interface
- G-6805 therapeutic instrument circuit
- Cadillac reversing light circuit diagram
- Rice cooker automatic rice cooking controller circuit
- Pulse water level controller circuit
- High-performance water level automatic controller circuit
- Simple water level controller circuit (2)
- Various lantern automatic controller circuits
- Long time timing controller circuit
- Fully electronic recorder circuit
- Using LA4160 as a recorder circuit
- Automatic degaussing device for tape recorder heads
- Recorder automatic power off circuit
