High-performance water level automatic controller circuit
Source: InternetPublisher:走马观花 Keywords: Automatic controller automatic water level control controller circuit Updated: 2020/08/25
Circuit working principle: When the water level in the water tank is lower than the sun point, F. , F2 composed of
RS flip-flop, Q outputs high level , the relay operates, and the water pump pumps water; when point B is immersed
in water, pin 6 of F2 becomes high level, the RS flip-flop maintains its state, and the water pump continues to
pump water. As the water level rises, when the water level reaches point 4, F. Pin 1 becomes low level
, Q terminal outputs low level, the relay is released, and the water pump stops; when the water level drops
below point A, F. The l pin becomes high level , the RS flip-flop enters the hold state again, and the water
pump still stops. Only when the water level is lower than point B, the water pump restarts, and the above process is repeated
. It is important to point out that the above process is when the water level in the well is higher than point D
; if the water level in the well is lower than point D, no matter what state the RS flip-flop is in, it will
be reset, that is, the Q terminal outputs low power. This stops the water pump and prevents the water pump from idling and
burning out, and also achieves the purpose of energy saving.
- How to use a microcontroller to control a servo motor?
- Design and selection of electric control valve system drive
- Model rocket launch controller circuit
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- DIY an electromagnetic levitation device
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Light-controlled circuit design and analysis
- Design and production of no-load automatic power-off device for household power supply
- Password type motorcycle anti-theft device
- GDK-1 type anti-exposure electric controller circuit
- A transistor photoelectric controller circuit
- Pulse water level controller circuit
- Password controller circuit a
- Two practical password controller circuits a
- Multifunctional password controller circuit b
- Multifunctional password controller circuit a
- Solar automatic tracking controller circuit
- Programmable lantern controller circuit 02
- The ever-changing sound and light analog controller circuit 06
