Exhaust fan automatic control circuit (1)
Source: InternetPublisher:蓝猫淘气 Keywords: Exhaust fan automatic control circuit composite pipe switch Updated: 2020/06/07
Circuit working principle: S1 and S2 are switches installed on the door frame . When the door is open
, they are disconnected and the circuit does not work. If someone enters the bathroom and closes the door
, S1 and S2 are pressed together at the same time, and the exhaust fan M is powered on. At the same time, the secondary DC voltage of transformer T
passes through S, to C. Fast charging, charging to the power supply voltage instantly. The composite tube
also receives base current through the 100 kfl resistor and is turned on, and the relay K is closed. When you open the door and walk
out of the bathroom, S1 and S2 pop open, and the exhaust fan is energized by K's self-protection contact K1 to continue
working. At the same time, S cuts off the base power supply of the composite tube, but the voltage on C passes through
the 100 kfl resistor, causing the composite tube to form a discharge circuit and maintaining the conduction of the composite tube, so that K maintains
the pull-in state. Until C. When the voltage on the exhaust fan is not enough to make the composite pipe conductive, K will be released
, causing the exhaust fan to stop working after a delay, which is more conducive to
exhausting the waste gas in the bathroom. The length of the delay time is determined by C. Determined by the value of C. Large
delay time, C. Short hour delay. S, for manual switch .
- DIY a practical audio-visual doorbell
- Design of water management system based on Internet of Things
- Battery equalization system and control method thereof
- XDH-2 electrocardiograph circuit
- One control three constant pressure water supply frequency conversion speed control circuit a
- JC3.5 hydraulic controller and its wiring a
- Smart transmitter circuit diagram with hart interface
- G-6805 therapeutic instrument circuit
- Human body approaching safety protection warning circuit
- Simple temperature control circuit diagram
- Diode Balanced Mixer Circuit
- Three primary color display circuit
- Forgotten money alarm circuit
- Water full alarm circuit
- Emergency braking circuit when accelerator is pressed accidentally
- Electromagnet control circuit
- Contactless switch conversion circuit a
- Two lamps and one switch incandescent lamp parallel lighting circuit
- Transistor leakage release protection circuit
- Transistor stabilized power supply circuit using composite tubes
