Water full alarm circuit
Source: InternetPublisher:酷到被通缉 Keywords: Alarm circuit BSP switch speaker Updated: 2020/12/28
Shown is a water full alarm circuit . When working, the switches S1 and S2 are closed. When the water level in the water tank rises to the specified depth
, the two induction pieces are conducted through the water in the water tank, causing the relay kA to absorb the table: at this time, an alarm can be sounded through the electric speaker , which is safe. The green light goes out and
the red light glows. The whole machine can be packed into a small plastic box. a:b The sensing piece should be installed at the upper limit of the water tank, with a distance of 2cm between the two pieces.
- A white light LED power outage emergency light
- Low cost LED automatic emergency light circuit
- Corridor automatic light-off device
- Motor speed photoelectric control circuit
- One of the circuits that control one light in multiple placesb
- Economical and practical delay light circuit
- Shock resistant soft start constant current LED lighting circuit
- SH-803R holiday lights ASIC
- 6-digit cathode fluorescent triode display circuit
- Touch lighting switch circuit three
- Electronic thermometer circuit
- Mixer built with analog multipliers
- Integrated synchronous detector composed of analog multiplier MC1596
- Amplitude modulation circuit composed of MC1496
- Crabo oscillator circuit
- Inductive feedback oscillator circuit
- OTL low frequency power amplifier circuit
- Guest arrival signal recognition circuit
- Motorcycle flash light circuit
- Sawtooth wave generator circuit (1)
