SR63 holiday lights ASIC
Source: InternetPublisher:常思一二 Keywords: ASIC lantern BSP Updated: 2020/07/26
After the 220V AC power is bridge-rectified by VDI~VD4, it is output from point a. One channel directly supplies power to the lanterns H1~H4;
the other channel is stepped down by Rl and stabilized by VD5 to output about 5v DC voltage for the integrated block A. . R2 and R3 form a voltage divider to provide synchronization signals
for integrated block A.
RP1, R4, C3 and SR63 and the internal circuit form a system oscillator. Adjusting the value of RPI can change the system oscillation frequency
and adjust the chasing speed of the four groups of colored lights. RP2 and the internal circuit form a dimming oscillation circuit. Adjusting the value of RP2
can change the dimming speed and the contrast between bright and dark lights . In the figure, the four control terminals DIM, Sl, so, and TIP are not connected. During
actual production, they should be connected according to the needs of the pattern according to Table 2-41 or use switches for switching operations.
- Example of LED AC drive circuit
- Delayed gradual lighting with protection function
- IRS2530D electronic ballast circuit diagram
- Low cost LED automatic emergency light circuit
- LED Signage with RS232 Port Operation Guide
- Electronic massage and acupuncture device circuit
- Lighting lamp voltage stabilizing circuit (2)
- One of the bead-type emergency light circuits
- Electronic music dimming desk lamp circuit
- Frost alarm circuit
- Electronic anti-asthma circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Poultry warming temperature control circuit
- Double detuned loop frequency discriminator circuit
- base amplitude modulation circuit
- Voltage series negative feedback amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
