SH-802 Holiday Lights ASIC
Source: InternetPublisher:super_star Keywords: ASIC lantern synchronization signal oscillation Updated: 2021/09/06
The holiday lantern controller circuit made with SH-802 integrated circuit
is shown in Figure 2-56. After the power supply is rectified by VDI~VD4, stepped down by Rl and current limited by VD5 and
stabilized by VD5, it outputs a DC voltage of about 5.IV, which is added to the VDD end of the integrated block to provide
power for the integrated block. R2 obtains the synchronization signal for the integrated block . R3 is the
external oscillation resistor of SH-802 . R4~R7 are the output resistors of SH-802. After power on, the four-way colored lights H1~H4 will
automatically change in cycles according to the program pattern stored in the chip. Press button SB to manually set the changing pattern. Each time SB is pressed, the pattern
will change.
- USB powered portable light
- DCD-1240 multifunctional rechargeable lighting
- Driving circuit for driving light-emitting diodes by IR53HD420
- Infrared remote control device circuit
- SC3071 touch step dimming light circuit
- Infrared remote control dimmer light circuit
- Two-way electronic music doorbell circuit
- Three-way music lantern circuit
- Remote anti-theft alarm
- Touch/wireless remote control dimmer light circuit diagram
- Eight-function multi-pattern lantern chain circuit using SH803
- High-power lantern chain circuit with adjustable luminous frequency for each group b
- One of multiple groups of high-power colored light chain circuits that flash in turn b
- Light chain circuit that glows along the four sides and from the inside out
- Three-way karaoke light renderer circuit
- Four-way flashing light string circuit (11)
- Use KD-1001 to make lantern controller
- LD168 audio voltage controlled lantern control ASIC
- LC172, LC171 audio voltage controlled lighting control special integrated circuit
- SH-811 Holiday Lights ASIC
