Floor small pumping automatic control circuit
Source: InternetPublisher:消失的歌 Keywords: Automatic control circuit Updated: 2021/02/08
Working principle of the circuit: The circuit uses two time base integrated circuits 555 as the central component
. The g pin and l pin of 555 are connected to the positive and negative poles of the power supply respectively. IC is used to control
the opening and closing of the water inlet valve of the reservoir at the bottom of the building, IC . Pin 4 of the reset terminal is connected to the positive terminal of the power supply and placed at high potential
. When the water level of the battery on the floor is lower than the C terminal, IC. The voltage of pin 2 is "low",
pin 3 outputs high level , LED2 lights up (indicating water intrusion), and relay K. Pulling in, the solenoid
valve opens to allow water inflow. When the water level crosses the C pole and reaches the mouth pole, lC. The potentials of pins 2 and 6
are both higher than 2/3 Vcc, and pin 3 outputs low level to stop water inflow and the pool is filled. IC: Used
to control the opening and closing of the water pump in the rooftop reservoir. In order to prevent the water pump from emptying,
pin 4 of IC2 is connected to probe D. The probe D is placed in the pool at the bottom of the building slightly higher than the opening of the pumping pipe. When
the water level of the pool at the bottom of the building is lower than pole D, the potential of pin 4 is "low". At this time, no matter
what the water level of the pool on the roof is, pin 3 of IC 2 outputs low level, relay K2 is released, and the water
pump stops pumping water; When the water level of the pool at the bottom of the building is higher than pole D, pin 4 is placed at high level.
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Manual automatic air compressor control circuit
- DC motor drive circuit composed of L293D
- Working principle of one Xipu STR soft starter controlling two motors
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Design and analysis of voice control circuit
- Simple three-phase motor phase loss protection circuit
- Electric vehicle battery charging protection circuit
- Night dog barking anti-theft reminder circuit
- Precious home appliance anti-theft alarm
- Homemade disinfectant circuit
- Rural fish farming control circuit
- Multi-channel patrol detection control circuit b
- Electronic rhythm control circuit
- Mobile phone camera flash control circuit
- Traffic traffic light control circuit
- Schematic diagram of motor PLC control circuit
- 24h automatic switching capacitor control circuit
- Relay control circuitb
- Wide input range non-synchronous voltage mode control circuit
