Energy-saving three-phase asynchronous motor phase failure protection circuit
Source: InternetPublisher:常思一二 Keywords: Three-phase asynchronous motor phase failure protection power saving protection circuit Updated: 2021/12/07
Working principle of the circuit: Use wires to lead out the Y terminals of the three-phase power supply of the motor,
and connect them to the capacitor C. C3, and through these three capacitors, it generates an
artificial Y connected to the neutral point. When the motor is working normally, the voltage at the neutral point artificially connected to Y
is zero, which is consistent with the neutral point potential of the three-phase four-wire, so the voltage between the two points is zero, the rectifier
has no output, and the relay K does not operate. When a phase of the motor is disconnected,
the voltage at the neutral point artificially connected to Y will rise significantly. When the rectified voltage reaches 12 V, the relay
will close. At this time, the AC contactor controls the four-way cutoff, and the contactor is released when it loses power, thereby
achieving the purpose of protecting the motor.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Peripheral circuit of automotive motor controller power supply chip
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Motor automatic cycle control circuit
- Motor self-starting circuit
- IGBT modules block overcurrent by controlling the gate
- Temperature control circuit design and analysis
- Design and analysis of voice control circuit
- Audio interface protection circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Resistive Neutral Leakage Protection Circuit
- Low voltage blocking overcurrent protection circuit
- Relay fixed time overcurrent protection circuit a
- Thyristor resistance-capacitance protection circuit c
- Motor protection circuit
- The structure and working principle diagram of various protection circuits c
- PTC three-phase asynchronous motor protection circuit three
- Three-phase asynchronous motor sequence control circuit
- Energy-saving three-phase asynchronous motor phase failure protection circuit
- Started three-phase asynchronous motor stall protection circuit
