Electronic prize winning machine circuit
Source: InternetPublisher:两手空空 Keywords: Electromechanical Updated: 2021/07/06
Circuit working principle: This circuit consists of two ICs. IC1 constitutes a pulse source, because
it is powered by C1 after the key switch S is turned on momentarily to charge the capacitor C1,
so the pulse source composed of IC 1 only oscillates for a while (more than ten seconds) and then stops. But
its oscillation frequency is high first and then low. In this way
, the ten LEDs driven by the pulse counting, decoding and display driver composed of IC2 will also
flash quickly, then slowly and then stop with the pulse output by IC2 .
- Binary clock design based on FPGA
- Battery equalization system and control method thereof
- Grain temperature measuring instrument circuit
- Vehicle electronic fuel gauge circuit
- RF leak detector circuit diagram
- Motorcycle anti-theft alarm circuit-a
- Thermocouple Temperature Transmitter
- One of the cooling fan automatic control circuits
- Commonly used oil pump motor control circuits for presses
- HTS fire alarm
- Household advance working remote control circuit - transmitter circuit
- Headphone circuit based on field effect transistor as silencer
- Headphone circuit using field effect tube as muffler tube
- G-80 air plasma cutting machine circuit
- Using CMOS to form a time-adjusted spot welding machine circuit a
- ZXG-500 DC arc welding machine circuit
- ZXG-200, 300 type DC arc welding machine circuit
- Small thyristor charger circuit four
- DC motor armature connected in series with resistor to start reverse braking forward and reverse circuit 2
- Motor armature connected in series with resistor to start energy-consuming braking one-way operation circuit 3
