DC motor armature connected in series with resistor to start reverse braking forward and reverse circuit 2
Source: InternetPublisher:红水杯 Keywords: Electromechanical DC motor Updated: 2020/08/19
202. The circuit is shown in Figure 3-202. The performance of this circuit is similar to Figure 3-201, except that a button is used instead of the main switch
In the figure, Ri and R2 are the starting resistors; R: is the reverse braking resistor; R is the discharge resistor ; SBi is the forward button;
SBz is the reverse button; SB3 is the stop button; KMi is the forward contactor; KMz is Reversing contactor; KM3 is a reverse
braking contactor; KMs and KM7 are accelerating contactors.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Servo motor pin diagram/working principle/application
- Design of an autonomous plant watering system using ATtiny85
- Use your smartphone to turn on/off the power in your home
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Simple three-phase motor phase loss protection circuit
- An experimental model of an infrared radio alarm
- Night dog barking anti-theft reminder circuit
- Password type motorcycle anti-theft device
- Differential amplifier emitter negative feedback gain control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Micro remote control receiving and control circuit
- fire smoke control circuit
- Car window control circuit
- Assembly line outage monitoring circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- Photoelectric detection output control circuit
- Steam iron temperature detection control circuit
- Small power electric heater temperature detection control circuit
