Toy electronic cat circuit (3)
Source: InternetPublisher:红水杯 Keywords: led Updated: 2020/02/15
Circuit working principle: IC 2 forms a simple low-frequency oscillator. IC 2 is a decimal
counting decoding integrated block. VD1 to VD4 in the circuit not only have the function of level signals at the output terminals
, but also have the function of isolating each output terminal from each other. LED 1 and LED 2 are color-changing
light-emitting diodes, and R1 and R2 are their current-limiting resistors.
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- How to build an electric vehicle EV charger
- Digital display time relay circuit
- Telephone line protection alarm circuit
- Gantry milling machine spindle control circuit
- Smart transmitter circuit diagram with hart interface
- Wired centralized control circuit that directly starts the water pump motor
- Small improved circuit of hanging electronic watch
- Slow logic pulse listener circuit diagram
- Sensor alarm circuit
- LED driver circuit diagram powered by solar cells
- Driving circuit diagram of a low-power LED bulb
- Dark activated LED flash circuit
- 38 LED energy-saving lamp circuit
- S8050 low-cost high-performance LED constant current power supply circuit diagram
- Positive terminal buck/boost LED constant current drive circuit diagram
- Wall wire detection circuit
- Light controlled night light lighting circuit
- Household electric blanket power saving circuit
- Light emitting diode (LED) display driver circuit
