Solar charger circuit
Source: InternetPublisher:newlandmark Keywords: Charger circuit solar charger LED voltage drop Updated: 2020/03/23
Circuit working principle: LED is a high-brightness light-emitting diode used for lighting and power display
. R is the current limiting resistor, its resistance = board voltage - LED forward voltage drop /light-
emitting diode current. VD1 and VD2 are step-down diodes. Generally, the forward voltage drop of silicon tubes is 0.6 V.
The two lithium batteries are equipped with overcharge and over-discharge protection circuits, and are switched to parallel or series connection
via S5 and S3 and S4. JF switch combination can output 2.5 V, 3.4 V, 4V, 6.5 V,
7.8 V, 8v (sufficient state) voltage.
- A wireless doorbell circuit
- LED digital clock language time reporting circuit
- Rice cooker circuit drawing 26_electronic type
- Triangle CRJ120-A multifunctional non-stick electric hot pot circuit diagram
- answering machine circuit
- Tube amplifier TDA1541 parallel circuit diagram
- Universal inverter deceleration braking circuit
- Chennuxi brand BCD-180 refrigerator circuit
- Printed circuit diagram of power converter
- Refrigerator shell live alarm circuit
- Teach you a thyristor dimming LED drive power circuit design
- LED emergency light circuit diagram
- LED drive circuit based on switching power supply
- Circuit using NCP1216 to drive LED
- LT3755 driver LED application circuit diagram
- LED constant current source circuit diagram using LM317
- Simple light-emitting display logic pen circuit
- LED lighting display detection circuit with overload protection
- Power outage sound and light alarm circuit
- Digital camera flash control circuit
