Simple light-emitting display logic pen circuit
Source: InternetPublisher:偷熊计划 Keywords: LED power display power supply Updated: 2020/05/22
This luminescent display logic test pen is composed of only a NE555 time base integrated block and a small number of peripheral components. This kind of test pen can be used to judge the high and low signal levels and the presence or absence of pulse signals in digital circuits.
The circuit is shown in the figure below, which shows a simple light-emitting display logic pen circuit composed of a 555 time base circuit. The 555 time base integrated circuit is connected as a multivibrator. When probe A is floating, 3DG6 has no base current and is cut off. Pin 5 of the integrated circuit is at +E potential. The multivibrator circuit is suppressed and does not vibrate. Pin 3 outputs high potential and the LED is on, that is, there is light and no sound. When probe A is connected to logic "0", pin 4 of the reset terminal of the 555 circuit is forced to reset, pin 3 outputs low potential, and the LED goes out, that is, there is no light or sound. When probe A is connected to logic "1", the voltage drop at both ends of R2 causes pin 5 of the 555 circuit to deviate from the +E potential, the multivibrator is controlled to start, and pin 3 outputs an audio signal with a frequency of 1kHz, HTD The transducer emits sound and the LED lights up, that is, there is light and sound.
![Simple light-emitting display logic pen circuit](http://www.eeworld.com.cn/circuit/upload/30a71f520a8f8ceb11fcf64717da3bb5/23c6cebb593a64548bc88d0485f3cd2b.jpg)
- What kind of circuit is a voltage regulator circuit?
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Detailed explanation of 5v charger circuit diagram
- Power supply circuit that can reduce LM317 ripple
- Design of electric vehicle charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Practical constant current charger-----Constant current charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- What sensors does the phone have?
- MAX1577V/MAX1577Z driving white LED circuit diagram
- Circuit using NCP1216 to drive LED
- Simple light-emitting display logic pen circuit
- Leakage alarm automatic control socket circuit diagram
- LED level meter driver integrated circuit diagram
- Wall wire detection circuit
- Three-phase alternating current detection circuit
- DC regulated power supply status display circuit
- Eight-way light-touch electronic interlock switch circuit
