Anti-theft alarm circuit
Source: InternetPublisher:太白金星 Keywords: sensor Updated: 2021/07/07
Circuit working principle: This early warning device is essentially an induction sequence switch circuit
to achieve the purpose of correctly connecting the phone and dialing the number. When someone is within 50 cm of sensor
, human body clutter is received by G, causing the resistance between the drain and source of field effect transistor VT1 to increase
. Pin 2 of IC 1 is low level , and the monostable delay composed of IC 1 When the circuit is working, pin 3
outputs high level and K1 is closed. The contact point of K1 is connected to the hands-free switch of the telephone set.
- Hot wire spark plug control circuit
- Video doorbell design based on Raspberry Pi
- How to build an electric vehicle EV charger
- Telephone cipher circuit
- Homemade disinfectant circuit
- Electronic mousetrap circuit
- Differential voltage or differential current alarm
- Infrared light controlled toy tank circuit
- Box type electronic mousetrap circuit
- Poultry warming temperature control circuit
- High-resolution 35 mm CCD image sensor, did you know?
- Ultrasonic proximity sensor circuit
- Circuit diagram of a thermocouple cold junction temperature compensation
- Color sensor amplification circuit
- Baby bedwetting voice alarm circuit
- Digital pressure measurement circuit
- Accurately identify three primary color circuits
- Bridge sensor transmit/receive circuit
- Sensor and AD7710/7712 signal conditioning ADC circuit
