High-resolution 35 mm CCD image sensor, did you know?
Source: InternetPublisher:aytwartoofyoroo Keywords: Sensor ON Semiconductor Updated: 2021/01/29
What is a high-resolution 35 mm CCD image sensor? What does it do? ON Semiconductor (Nasdaq: ON), which drives energy-efficient innovation, launches a new 43-megapixel (MP) resolution The charge-coupled device (CCD) image sensor, whose optical format is conveniently 35 mm, extends capabilities to applications requiring stringent high-resolution industrial imaging. The KAI-43140 is suitable for applications that require extremely high-resolution image capture and excellent image uniformity, such as high-definition (HD) and ultra-high-definition (UHD) flat panel displays for end-of-line inspection and aerial photography.
The KAI-43140 uses a new 4.5 um Interline Transfer CCD (ITCCD) pixel, which improves resolution by 50% compared to the previous 5.5 um design, while maintaining key imaging performance. The device features a true motorized "global" shutter that supports full resolution frame rates up to 4 fps using a flexible 1, 2 or 4 output readout architecture. The KAI-43140 has the same package and pin definitions as the popular 29 MP KAI-29050 and KAI-29052 image sensors, allowing it to be incorporated into existing camera designs with only minor electrical changes, accelerating the adoption of this new device design Improve time to market for new products while maintaining continuity with existing camera and lens installations.
The KAI-43140 provides extremely high resolution, high-quality, and uniform image capture over a wide range of exposure times. All these advantages are critical for applications such as flat panel inspection - the resolution requirements of the inspection system will vary with the display itself. As the resolution continues to improve. The new devices also enable surveillance and aerial photography systems to capture more detailed images, or from higher altitudes, to speed acquisition times and reduce costs.
Herb Erhardt, vice president and general manager of the Industrial Solutions Division of ON Semiconductor's Image Sensor Division, said: "Currently, only CCD technology can meet the image uniformity requirements of many industrial imaging applications; at the same time, continuous pixel development is required to achieve higher resolutions. .KAI-43140 allows camera manufacturers and end customers to continue to push the boundaries of high-resolution image capture without sacrificing the image quality these applications demand."
ON Semiconductor now provides an engineering-grade version of KAI-43140, and the mass-production version is planned to be launched in early third quarter of 2018. KAI-43140 is packaged in ceramic PGA and is available in monochrome, Bayer color and Sparse Color configurations.
To assist customers with new camera development incorporating the KAI-43140 and other image sensors from the ON Semiconductor product lineup, the company offers kits that support complete evaluation, including still image and video capture, region of interest (ROI) readout, and pixel summation . Other customized testing functions can also be configured. Customers can contact their local ON Semiconductor sales representative to purchase an evaluation kit or inquire about a live demonstration of the KAI-43140. The above is the analysis of the high-resolution 35 mm CCD image sensor. I hope it can be helpful to everyone.
- Benefits of Wide Bandgap Technology for Power Converters
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Practical and convenient fax machine power supply control circuit
- Energy-saving motorcycle rectifier regulator
- LNK304 non-isolated LED light string driver circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- 3~15V 10A adjustable voltage regulated power supply
- USB power socket using the car battery
- Electric bicycle battery charger circuit
- MAX1811 Lithium Battery Charger Production
- Interface technology circuit analysis of sensors used in ESP
- Based on IH-3605 humidity integrated sensor hygrometer circuit
- Low temperature temperature sensor
- Intelligent fire alarm system circuit module design
- Remote anti-theft alarm
- One of the inductive anti-theft alarm circuits using RD627 sensor
- Soil drying alarm circuit
- Thermocouple Thermometer Circuit
- Temperature regulating circuit using platinum measuring sensor
- Basic connection diagram of bridge sensor and XTR104 02
