Gas alarm circuit (1)
Source: InternetPublisher:elleny Keywords: Alarm circuit gas alarm LED Updated: 2021/08/28
Circuit working principle: Normally, when there is no gas in the air,
the resistance value between the A and B poles of the gas sensor QM-N5 is large, the potential of the control terminal 7 of the LED bar driver integrated circuit Ic
is almost 0, and its output terminal Pins 2-6 are all low level ,
LED1 to LED5 are all off, the alarm circuit and ventilation control circuit do not work
; when the gas in the air reaches a certain concentration,
the resistance The value becomes smaller, there is a certain voltage at pin 7 of the control terminal of IC1, the corresponding output terminal outputs high level
, and the corresponding LED lights up.
- How to use MFRC522 to create an RFID card reader security system
- Design of hydroponic farm based on IoT
- How to calculate the power loss of RS-485 transceiver THVD1550
- Grain temperature measuring instrument circuit
- One control three constant pressure water supply frequency conversion speed control circuit a
- Electronic mousetrap circuit
- Infrared blind cane circuit diagram
- Infrared light controlled toy tank circuit
- Two-channel SL320 level indication circuit
- Commonly used oil pump motor control circuits for presses
- Teach you a thyristor dimming LED drive power circuit design
- Circuit diagram of a high-brightness and energy-saving LED lamp cup
- 38 LED energy-saving lamp circuit
- Leakage alarm automatic control socket circuit diagram
- Working principle of single touch mode light switch
- 3W high power LED drive circuit diagram
- LED level meter driver integrated circuit diagram
- Inpatient pager circuit
- Constant temperature measurement circuit
- Quiz quizzes circuit
