Leakage alarm automatic control socket circuit diagram
Source: InternetPublisher:通通 Keywords: LED power supply and other power circuits Updated: 2020/06/21
Circuit working principle: lC is a special leakage protection switch integrated circuit of RS101A type. The LED is a BTS11405 stroboscopic light-emitting diode, which emits a flash as long as the power is turned on. The mains power passes through the capacitor step-down rectifier and voltage stabilizing circuit composed of C1, ZD1, and VD, and then the DC voltage obtained after filtering by C5 is used by this circuit.
- How about the boost converter TPS61299?
- Build a simple buck-boost regulator and test it on a breadboard
- Practical and convenient fax machine power supply control circuit
- Single-power supply circuit for ISO122P/ISO124
- Driving circuit that controls LED brightness using PWM signal
- LED Driver ZD1680
- How to use SBR to improve power conversion efficiency
- A simple positive and negative power supply circuit
- A novel and practical DC low voltage stabilized power supply
- 3~15V 10A adjustable voltage regulated power supply
- Teach you a thyristor dimming LED drive power circuit design
- LT3755 driver LED application circuit diagram
- LED driver circuit diagram powered by solar cells
- BA6104 five-digit LED level meter driver integrated circuit
- heartbeat sensor
- Dark activated LED flash circuit
- Optocoupler isolation circuit with PNP transistor current amplification
- Leakage alarm automatic control socket circuit diagram
- Working principle of single touch mode light switch
- MEMS strobe driver circuit diagram
