Bistable switch circuit diagram
Source: InternetPublisher:兰博 Keywords: bistable switch control double d flip-flop integrated circuit cd4013 Updated: 2020/09/28
The working principle of the bistable control circuit is as shown in the figure. Here is an example of a multi-place control switch for reference. Assume that the load is a light. When button AN1 is pressed, a positive pulse is given to the "CP1" terminal of IC1, causing the Q1 terminal of IC1 to output a high level, so the "CP2" terminal of IC2 also inputs a positive pulse, and its IC2 The Q2 terminal becomes high level. At this time, because the ④ pin of the controller DM is connected to the Q2 terminal of IC2, it is naturally also high level, and the signal light H lights up. Press AN1 again, the Q2 terminal of IC2 returns to low level, and the ④ terminal of controller DM also changes to low level and turns off H. In this way, each time AN1 is pressed, the working state of H can be changed.
This application circuit uses a dual D flip-flop integrated circuit CD4013, which contains two D flip-flop circuits. One of the D flip-flop circuits is used as a pulse broadening circuit. Its purpose is to prevent the pulse from being caused by the jitter of AN1. The number is uncertain; the other D flip-flop constitutes a bistable flip-flop. The method of using this circuit as an energy-saving lamp is: when you go upstairs, press AN1 and H will light up. After entering the room, press ANn again, and H will go out. The difference between it and the monostable energy-saving lamp is that the time from pressing AN1 to pressing ANn can be arbitrary and is not limited by time and space.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Analysis of the working principle of car garage door lights
- How to build a simple tachometer using an infrared reflectance sensor
- DIY an electromagnetic levitation device
- Introduction to the internal structure of the Delta winding motor
- IGBT modules block overcurrent by controlling the gate
- Design and production of wireless multi-location control switch circuit
- Home wireless burglar alarm circuit
- Homemade anti-theft watchdog
- Typical application circuit diagram of photoresistor type light control switch
- Circuit diagram of a sound and light dual control energy-saving switch
- Egg heating control circuit
- fire smoke control circuit
- Digital camera flash control circuit
- time control circuit
- Bistable circuit control motor forward and reverse circuit
- Motor automatic mutual switching circuit controlled by transfer switch a
- Bistable frequency dividing circuit
- Sound-activated bistable electronic switch circuit
